General Automotive Discussion
Big Chevy transmission problem, need help
Old Feb 9, 2006 | 11:31 PM
RA122225's Avatar
RA122225
Banned
Alright, my friend has a 1997 S10, 4 cylinder, auto. It is in pretty bad condition, but mechanically sound... until today. Previously, the transmission had been slipping, but today it went out. The truck will just barely creep forward for a few hundred feet, then it stops moving until it cools down. This sounds like a burnt torque converter to me, but the thing that gets me is the leak. Actual ENGINE oil is leaking from the back of the transmission right from the yoke. How it gets back there is new to me. The truck is running at normal operating temperature, but something in the transmission is bad wrong. I pulled the dipstick to have a look at the fluid (he had just changed it a few weekends earlier) and it wasn't even registering now. I then pulled the engine oil dipstick (he checked it earlier that day and said it was full) and now it was completely dry. Any thoughts?
Old Feb 10, 2006 | 01:12 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Originally Posted by jcfb
Any thoughts?
Maybe leaking both engine oil and tranny fluid? Maybe leaking engine oil up high on the engine and with a little wind from driving the oil is running clear to the back of the tranny? I can't think of any reason for there to be engine oil in the tranny unless someone is putting it in there, and this would be a first for me . Since the thing is only moving forward a few hundred feet and since the tranny is low on fluid, I'd top it off (tranny warm, engine running and in park) and see what you've got. I have to wonder if your buddy filled the tranny all the way when he changed the fluid (ie, engine running and tranny fluid warm). Finally, and I doubt this vehicle has one, but if there is a vacuum modulator on the tranny check the vacuum line leading to it for the presence of fluid in the line.
Old Feb 10, 2006 | 04:41 AM
fellro86's Avatar
fellro86
If the trans oils is burned bad enough, it will look like motor oil. I just changed the trans in my van, I knew it was going, but kept pushing my luck, trying to buy time, well, the quarters ran out, and it left me stranded. The oil in it was so black that it could be mistaken for motor oil... This isn't uncommon, whether it is clutches slipping, or converter burned up.
Old Feb 10, 2006 | 09:29 AM
ggarrahan's Avatar
ggarrahan
If the Chevy transmission has a vacuum modulator, it's possible to pull transmission fluid into the engine if the modulator is defective, but since the engine is the vacuum source, I don't see how the reverse could be true. There is no direct connection between the engine oil and the transmission fluid, so engine oil is not migrating internally. I agree with the above comments that either the engine oil is being blown back to the tailshaft area, or what you are really seeing is burnt black transmission fluid. I'd bet on the latter. Either way, the truck sounds like a reject from the junkyard, and is probably not worth fixing.
