Hard Shifting, No Pedal....HELP!
Old Feb 9, 2006 | 09:21 PM
BoomerPower's Avatar
BoomerPower
Well I am having some difficulty getting my truck into gear. It's lost most of the pedal to it. It was shifting a little rough so I added trans. fluid and thought that could fix the problem because it needed some. When I left my shop to go home I couldn't get the truck into gear. Not a whole lot of grinding, it just wouldn't move into position. So I checked the slave cylinder and it had barely any fluid in it. I filled it up and tried pumping the clutch to maybe get it into the system. It helped a little and I could get it into a gear after a few tries. Still not much pedal. Could there just be air in the system now? If so is there any way to bleed it out? Or am I in for some major trouble here? Any ideas will help out greatly. Thanks alot.
Old Feb 13, 2006 | 07:59 AM
bigdan4712's Avatar
bigdan4712
sounds like your clutch needs replaced..if you do replace it, dont be a cheap-o...buy the whole kit....how many miles are on the truck?
-dan
