Vent window seals
Old Feb 9, 2006 | 07:59 AM
Okiedokie's Avatar
Okiedokie
Vent window seals
Before I resort to silicone, am I the only one having difficulty sealing vent windows on a slant cab? Used new Drake seals, can't seem to make any adjustment that allows full seal contact. Joe
Old Feb 9, 2006 | 03:06 PM
Scott123's Avatar
Scott123
I had major frustration on my 51, so I know what you're going through. I resorted to bending and forming the metal frame the seal goes in - and you can't just do it once and bolt in and go. It took SEVERAL cycles of installing it, seeing it was still not right, taking it out, tweaking the rubber's frame, install, etc. Even when I got that seal correct on the frame, found out my vent windows that were glued in by the window shop were cockeyed in the frame and wouldn't seal on the division bar, so they had to come out next. I'm sure it's not what you wanted to hear, but it sucked.
Old Feb 9, 2006 | 03:27 PM
Okiedokie's Avatar
Okiedokie
The only other slant cab that I am familiar with in my area has siliconed his. I may need to do the same. Hate the wind noise from them, plus they leak. Joe
Old Feb 9, 2006 | 05:11 PM
Jag Red 54's Avatar
Jag Red 54
Mine are Carpenter and fit great. I am not a big fan of Drake. Maybe that's the problem. I would call drake and tell them the problem you are having. Maybe they got a bad shipment in and will send you a better pair. It can't hurt to ask. Jag
Old Feb 9, 2006 | 05:13 PM
Okiedokie's Avatar
Okiedokie
Thanks Jag. I will look into that. Joe
Old Feb 9, 2006 | 05:37 PM
kdmcinnes's Avatar
kdmcinnes
No you are not the only one, for two years I have battled the same thing on my 56, I have decided that I will never win that battle.
Kyle
