Code 33 (EGR not registering) on my e150
Old Feb 9, 2006 | 07:49 AM
dgeist's Avatar
dgeist
Hi, I have a 1988 E150 with a 5.0 EFI. I ran the computer codes yesterday and other than the system-pass code, only got a "EGR not registering" (either 22 or 33, can't remember). in any case, would this simply be a case of a bad position sensor or is it worth tearing apart the entire EGR and doing a full diagnosis.
Thanks.
Dan
Old Feb 15, 2006 | 11:19 PM
RJPstruck's Avatar
RJPstruck
I just had the same problem on my 95 f 150. I put a new egr and a egr position sensor on. But it turned out to be the egr vacuum selenoid. I don't know how different our trucks are, but check all these things. Easiest way I found to check Selenoid, is to wait until it suppose to open, best if done when you come back from a drive. Pull vacuum line of selenoid that goes to egr and see if you have a vacuum. If not than replace selenoid. if so replace egr and egr position sensor.
Like I said , not sure how different yours is to mine.
Gunnerboy
Feb 3, 2016 06:31 PM
RUSTY_BUT_TRUSTY
Aug 4, 2015 06:26 PM
BigB1975
Feb 28, 2014 07:35 PM
ctruf1504x4
Apr 4, 2011 12:00 PM
Reckless
Jan 30, 2010 01:22 PM
