No Heat Again
Old Feb 9, 2006 | 03:21 AM
diesel-weasel's Avatar
diesel-weasel
Thumbs down No Heat Again
2months ago i changed my thermostat because of low heat, bought a stat from napa .NO good!had it replaced .will not heat up at all,Iguess i will have to go to navistar for the org. one has anyone had any problems with afretmarket stats?
Old Feb 9, 2006 | 06:52 AM
mistakenID's Avatar
mistakenID
I've had trouble with aftermarket stats for the last 10-15 years. Had them come apart, stick open, stick closed, stick mid way. I know it's not just me as my neighbor and a friend has noticed the same problems.
The only stat I've not had a problem with are the ones made by Robert-Shaw.
Old Feb 9, 2006 | 08:22 AM
PLC7.3's Avatar
PLC7.3
What can I say.........
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
CAUTION:
Do not attempt to repair any thermostat. It should be replaced if it is not operating properly.
Check any new thermostat before installing it for correct opening temperature. Before suspending in boiling water, with a flashlight check where the rubber and the flat metal flange meet for bad seal. Tstat should start to opening barely at 180-192f, fully open 200-212f, allow to cool and check for rubber seal again.
Removal: Disconnect batteries, drain 4+ gals A/F, remove: as required, fan belt, alternator set aside, alt bracket, remove filter support from fuel filter then e/block. Disconnect upper rad hose at rad, remove tstat bolts and housing. Clean both faces, depression and holes in block, ensure check ball in goosekneck is clean, free and rattles "do not remove".
Installation is reverse proceedure, I do not use sealant on gaskets and faces. REMEMBER the tstat pellet(copper end) goes into the block. I do use a "very small amount" of sealant on the edge of the tstat face when installing into the recess, now go for coffee, allow sealant to setup, this has saved me from tstat slippage when the gasket and goosekneck are installed. Replace all items in reverse order......
Manifold bolt torque......... 20ftlbs
F-250 WARHORSE
Jul 27, 2011 01:34 AM
koboss1
6.4L Power Stroke Diesel
29
Feb 3, 2010 10:12 AM
aussie01
Mar 5, 2009 08:28 AM
joe35098
Jan 17, 2006 08:09 PM
tazmania18235
Mar 15, 2004 05:04 PM
