using newer flywheel with a top loader 4speed?
Old Feb 8, 2006 | 11:29 PM
misunderstood's Avatar
misunderstood
What's everyone?Ihave a 1979 ford f-150. 1978 302 with a top loader 4 speed.I bought a 5.0 fuel injected engine out of a ford 89 bronco.I'm converting the EFI to a carb set-up.My question is what flywheel to use?Because i'm keeping the top loader.I know there is the difference in weight balance of a newer one compared to the older one.I just don't know if the newer flwheel will work with the top loader.help please
Old Feb 9, 2006 | 06:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 9, 2006 | 07:27 PM
TigerDan's Avatar
TigerDan
Keep the same flywheel that's on the '89 5.0 now. The splines on the transmission input shaft should be the same, so you should even be able to stay with the same clutch. You'll need to count the teeth on both flywheels, if they're the same you should be good to go.
kenwoodul
Feb 10, 2014 05:35 AM
stinkfist
13
Feb 14, 2008 08:26 PM
Soaper Steve
Nov 1, 2004 10:28 AM
jaroh
1966 - 1977 Early Broncos
34
Jul 18, 2004 08:13 PM
bsprowl
Sep 5, 2001 12:34 AM
