ok i am still a lil new to the diesel thing. i have a 94 f350 4x4 7.3 non-turbo. i need to find a good rebuilt kit...you know rings rod bearings, cam bearings, mains, etc. where can i find this stuff at a good price? thanks
Why not try your local *IH/Navistar dealer* they built the engine........ Remember boring out is forbidden unless you intend to sleeve it after.......... also do not mill the heads there is no spare metal........
Per AERA specs:
Stem to guide clearance (intake & exhaust): .0013" - .0055"
Valve height (measured from top of valve to "deck" height)
Intake: .042" - .054" Exhaust: .051" - .063"
Minimum head thickness (from "deck" to valve cover surface): 4.7950"
MISTER MAD i havebeen looking around to for a kit in the near feature,i came across a place called Rock Auto.com /dbphp/dbpage you can pick out what you want ,but if anyone knows anything negitive about them SpeeK OUT!!! because i have been known tonot make the right choice before .they carry fel/pro& sealpower
ok thanks for your guy's advice. i have to get the block checked for cracks first then i will call the kinda local (its a few hours away) IH/Navistar dealer but im guessing they are gonna be high on their price but its probably for the best.
and diesel-weasel,
thanks, i will check out rock auto.
