cab
Old Feb 8, 2006 | 07:29 PM
diablosport76's Avatar
diablosport76
cab
will a 1979 ford f150 cab fit on my 1976 ford f250 frame?
Old Feb 8, 2006 | 07:30 PM
ford390gashog's Avatar
ford390gashog
yes they all swap. unless it is 4x4 to 4x2
Old Feb 8, 2006 | 09:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
You may have to change transmission hump covers tho. The manual transmission cover is higher than the one for an automatic. Factory AC is different than the heater only models. The wiring is different for the instrument cluster etc for various years and options.
Make sure you keep your VIN tag and data plate.
Old Feb 9, 2006 | 06:25 PM
diablosport76
wat would i have to do for a 75 ford cab 2wd to fit on my 4wd
Old Feb 9, 2006 | 08:19 PM
wfordpower's Avatar
wfordpower
The tranmission hump would be the one big thing I would say that u would change but I am sure like everyone said wiring would have to be changed or modifield to work Good luck
Old Feb 9, 2006 | 09:41 PM
plowpusher's Avatar
plowpusher
you may have to drill new rear mount holes an easy way to do this is put the mounts on the frame put the cab on, aline the cab on the frame tighten the front mounts, get a long 1/4 in drill bit from the hardware store, center the drill in the rear cab mount drill all trhe way through, then from the top use a holesaw the same size as the stock mount, hole saw through the first layer then use a 7/16 inch dril through the next layer/s then it should bolt right up. I've done this a few times and took a 7/16 bolt (same size as the cab mount bolts) cut the head off, center drilled it on the lathe 9/32 and use it for a guide for the 1/4 drill bit the tranny hump should be a bolt in deal
