2002 Expl driver side interior panel removal 3rd row
Old Feb 8, 2006 | 06:50 PM
Chris50's Avatar
Chris50
All,
I've got an '02 Explorer XLT 3rd row.
What steps should I take in removing the interior panel on the driver side next to my third row. I need to remove it in order to take care of a blend door fix because the rear climate controls will not heat and there is the signature clicking noise back there. Thanks much for suggestions.
Chris50
Old Feb 8, 2006 | 09:40 PM
mountaineer man's Avatar
mountaineer man
I hope this is enough i tried to copy the pictures too but was unable too
Removal
µ 1. If equipped, remove the retractable cargo cover.
µ 2. Remove the liftgate scuff plate (13144).
1 Starting at either end and working along the liftgate scuff plate, use Windshield and Molding/Trim Removal Kit to remove the scuff plate.
2 Remove the liftgate scuff plate.
µ 3. If equipped, remove the rear power lock switch assembly.
l Disconnect the electrical connector.
4. Remove the B-pillar trim panel. For additional information, refer to «Trim Panel—B-Pillar».
µ 5. Remove the three rear quarter trim panel screws.
l Position the carpet aside to gain access to the screws.
µ 6. Remove the rear safety belt anchor nut.
µ 7. Open the rear safety belt guide bolt cover.
µ 8. Using the special tool, remove the rear safety belt guide bolt.
µ 9. Remove the quarter trim panel (31012).
1 Remove the pin-type retainers.
2 Feed the safety belt webbing through the opening in the quarter trim panel.
3 Remove the quarter trim panel.
Installation
µ 1. Install the quarter trim panel.
1 Feed the safety belt webbing through the opening in the quarter trim panel.
2 Position the quarter trim panel.
3 Install the pin-type retainers.
µ 2. Using the special tool, install the rear safety belt guide bolt.
µ 3. Close the rear safety belt guide bolt cover
µ 4. Install the rear safety belt anchor nut.
µ 5. Install the three rear quarter trim panel screws.
6. Install the B-pillar trim panel. For additional information, refer to «Trim Panel—B-Pillar».
µ 7. Install the liftgate scuff plate.
1 Position the liftgate scuff plate.
2 Start at either end and work along the liftgate scuff plate, pushing it into the floor panel.
µ 8. If equipped, install the retractable cargo cover.
Old Feb 9, 2006 | 11:02 AM
Chris50's Avatar
Chris50
Thanks much Mountaineer Man! Did you get the pics and instructions from a manual that can be purchased at a retail store?
Chris50
Old Feb 9, 2006 | 02:50 PM
mountaineer man
the info came from my ford cd look by truck year on ebay thats how I found mine.
