If I turn my truck off and let it sit for more than 5-7 minutes I have to pump the pedal to get it started. Any time before that time period the bugger starts right up. I am at a loss for this one seems it should be starting better when its warm. Is my gas going somewhere? If so how do I solve the problem?
This is just a thought - maybe the gas (inside carb and intake)is evaporating off of something when it's warm and off? Does it do the same thing during the winter?
I have had the same problem with mine since I got it. The swap from cast iron intake to aluminum intake and one barrel to four barrell seemed to help. Things got even better when I made a phenolic spacer to raise the carb up off of the intake. I was thinking vapor lock was the problem.. It seemed to be much worse in the hotter part of the year. Anybody else got some input on this?
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy C intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals, turbos, tips, and 02's
MSD6A w/Blaster Coil
Headlight relay system (Delanty style)
Overhead Mount FM-CD etc.
R-134 A/C system (I'm cool)
Get an "insulator" gasket from a speed shop, or large auto part's store. Your right about the fuel going somewhere! It's evaporating from the extreme latent heat of the engine.
Extreme latent heat? That sounds bad but this gasket you think will do me some help huh? Cool. Thought about adding a spacer to get the carb. up off the manifold a little more any thoughts on that? I have a alum. manifold already.
The fuel is boiling out of the float bowls. What carb do you have? When I switched from Holley to Edelbrock it was a lot better, its still touchy when it gets above 85 outside
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jun-01 AT 02:44 PM (EST)[/font][p]A plastic or phenolic spacer under the carb helps also. About 1" thick. You can buy them out of Summit or Jegs. The air filter base makes a difference also. If you have the stock base or a drop (lo-profile) base, you created a little dome over the carb thats holding heat in. The aluminum manifold dissipates heat faster than iron, so it isn't helping the cause. I have the same problem through the summer months and just kind of deal with it. Mine will start better and stay running with the Edelbrock though so that was the biggest help.
Also, if you have headers, they're heating things up too. This summer I'm building a cowl induction hood to open up some airflow across the engine and cool things down.
Dave,
[font color=red size=2]I had the same problem with my '73 390 with a cast intake and Edelbrock. I tried an aluminum spacer and it didn't help. Then I tried a plastic 1" spacer and it cured the problem. Be sure to get one made of plastic, or some other insulating material, not metal.
Marty
"Cleverly Disguised as a Responsible Adult"[/font]
