Missing Stumbling
Old Feb 8, 2006 | 05:33 PM
chrisvman's Avatar
chrisvman
Missing Stumbling
I Have a 1990 Ford F250 351W. I have replaced the map sensor, plugs, wires, cap and rotor, Fuel pump and fuel filter, ignition modual, pickup coil. I have the time set to 10 deg btdc. The truck will run fine for the first 5 minutes then will start to stumble if i accelerate hard. it will hold speed once it gets there. But when the engine is cold this is not a problem. Any help would be helpful.
