ABS Light on 2000 Explorer
Old Feb 8, 2006 | 05:11 PM
kevinkeil's Avatar
kevinkeil
The light had come on for about a month. We took it in to redue the brakes but when they finished work the light still is displaying. Any ideas on what I could do to get the light to turn off without going to Ford?
Thank you.
Kevin Keil
Old Feb 8, 2006 | 06:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 8, 2006 | 11:49 PM
gpyles01's Avatar
gpyles01
I had this problem in my 2000 xplorer 5.0L...In my case it was a ABS inertia sensor in back right wheel or axle ....not sure if this will help or not...but in these newer cars it can be many things...
Old Feb 9, 2006 | 10:21 AM
vette599's Avatar
vette599
It could be a wheel sensor or the rear diff speed sensor.I had my rear sensor changed a few months ago.I had the same problem.You will have to have the codes read to see which one it is.Hope this helps.
