CCA's
Old Feb 8, 2006 | 04:28 PM
MadMedic20's Avatar
MadMedic20
CCA's
How many CCA's (Cold Cranking Amps) should your battery be rated at? I have a problem with an E350 PSD not staarting in the morning. It will run all day long start and stop, starts up just fine but let her sit over night and she cranks fine (a little slow) but wont start. Have to use a battery charger.
I noticed that one battery is an 850 CCA battery but the other is only 600CCA. Does that make a difference? What should I be using? 2 800's two 850's? This is in an ambulance, so it has the beast alternator and so on. It also has battery disconects mounted on the drivers seat base, and they are turned off every night.
Old Feb 8, 2006 | 10:20 PM
earnies2's Avatar
earnies2
If your batterys are turned off every night than that elimenates the vechicle from the problem. your batteries should be of the same cca and they should be replaced together one weak battery will drain down a good battery I always use 1000 cca batterys in my PSD and i also have the 200 amp alt!!!
Old Feb 8, 2006 | 10:28 PM
96 Power Stroked's Avatar
96 Power Stroked
2*850 CCA batteries should be plenty to start these animals. you may have problems else where. When you start it cold does it smoke bad? plugged fuel filter(wax build up). just some ideas.
Old Feb 8, 2006 | 10:34 PM
earnies2's Avatar
earnies2
Read his post !!!!!!starts up just fine but let her sit over night and she cranks fine (a little slow) but wont start. Have to use a battery charger.
Key words ^^^
Old Feb 9, 2006 | 08:45 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The stock batteries were 1000CA and 800CCA, the 600CCA in yours is probably pulling the big one down some. First thing in the morning the glow plugs are pulling a huge load on the batteries...probably have a weak one. I would speculate that a pair of new 850's will do the trick.
Old Feb 10, 2006 | 04:47 PM
MadMedic20's Avatar
MadMedic20
Seems to have been a weak battery. I swapped out that battery with another that is almost brand new and starts fine every morning now. That new battery is an 800 CA and 600CCA. But that is the battery recomended by Ford. Its a slim battery designed for the E350 to fit just infront of the blower motor. Part# BXL 50. But now it seems the starter is going bad. Just my luck. Makes a bad grinding noise when starting sometimes.
sunuvabug
May 29, 2014 07:18 PM
UaVaj
Sep 7, 2013 09:08 PM
AndeyHall
Oct 4, 2011 04:47 PM
80s Trucker
Electrical Systems/Wiring
Dec 19, 2009 08:16 AM
thedaddycat
Dec 21, 2008 08:55 PM
