Casting Numbers
Old Feb 8, 2006 | 03:57 PM
1971FordGuy's Avatar
1971FordGuy
Casting Numbers
I'm trying to figure out if I have a good Engine or not the numbers are C7ME-A
Old Feb 8, 2006 | 05:53 PM
mercman1953's Avatar
mercman1953
from a quick search you may have a 428 4-v motor. this would be a very good engine to have. Is that number off the side of the block behind the starter? Let me know I will look it up in the Ford interchange manual.
Old Feb 8, 2006 | 06:51 PM
ford390gashog's Avatar
ford390gashog
well the number means little. try the FE forum . the C7ME-A is a common block. i have had 6 of them. most 4.05 bore
Old Feb 9, 2006 | 10:04 AM
1971FordGuy
I found the number on the front of the motor on the opposite side as the oil filter and almost in the same spot as it on the other side.
Old Feb 9, 2006 | 10:20 AM
BobbyFord's Avatar
BobbyFord
C7ME-A is a common # found on FE blocks. Could be 352, 390 or 428, pretty much anything but a 427. Measuring bore and stroke is the only way to tell for sure.
Old Feb 9, 2006 | 03:12 PM
1971FordGuy
I know its a 390 but I just wondered what kind of Mercury car it came out of the C means the 60's the 7 mean's 67 the M means Mercury and the E means the engineering dept. but I don't know how to tell what kind of car it came out of. What did mercury have that year that offered the 390?
Old Feb 9, 2006 | 03:34 PM
4Cammer72's Avatar
4Cammer72
monterey for one.
Old Feb 9, 2006 | 03:39 PM
ford390gashog
nope, it never came from a merc . plenty of those came stock in trucks with that casting number. the ford casting numbers were random. also unless you look at the date code the "7" means nothing. they used C7ME-A blocks up until the early 70's then the D3TE-A block came on sceen.
Old Feb 9, 2006 | 04:08 PM
1975Ford's Avatar
1975Ford
The numbers cross over to a '67-'70 428 c.i.d, 428-4V, Police Interceptor with a 4.13 inch bore and 0.015 deck height and a 3.98 inch stroke , Cobra Jet or could also be a 1967-70, 330MD c.i.d., Medium Duty Truck.
C7ME translates to a 67 Mercury Engine, the -A represents an original part with no revision on the original cast.
What the cast number on the heads? I'll cross over those to see if they match with the engine block.
Old Feb 13, 2006 | 03:02 PM
1971FordGuy
I think the heads castings are 68AE but I haven't looked at it in awhile.
Old Feb 13, 2006 | 03:04 PM
ford390gashog
68AE-H heads are just run of the mill heads.
Old Feb 13, 2006 | 10:46 PM
Fomoko1's Avatar
Fomoko1
The FE family of engines casting numbes are very confusing and flustrating to say the least. One way of determing the stroke is to remove a spark plug and measure the stroke with a small rod through the hole.
