Where and how did you mount Speakers?
What's really great about the abs is that you can glue it with abs pipe cement from the hardware store and also it can be shaped by warming it up until it gets pliable. The spray glue for the covering fabric also sticks to it very well. It cuts extremely easily as well, even curved lines, just carefully score it (you don't have to go very deep) along the cut line with a sharp utility or Xacto knife and bend it backwards until it snaps along the line.
I put my speakers in my kick panels. Since I used Roddoors, stability was not a problem. Used jute backed foil in cab and kick panels. They work great for me. I do not need concert hall sound to please my ear. I can enjoy my music at 70, windows up or down. Heck there is as much wind noise wichever they are. Joe
Look in your yellow pages under plastic, rod and sheet, suppliers Most plastic supply houses have it or can get it for you, shouldn't be expensive altho you may have to buy a full sheet, especially if it needs to be ordered. 3/32" is a good all around thickness. Rod doors also sells it in smaller sized pieces for repairing or customizing their panels. If you have a local stocking supplier ask if they sell cut offs, pieces they consider waste, but that are often pretty good size for smaller panels like kick panels. Often sold by the pound rather than by the sq ft.
Ax is right on about where to buy the ABS. If my memory is correct, seems like I paid $32 for a 4x8 foot sheet. I also made by door panels out of it. See the pics in my gallery.
I found that the thicker stuff is a little more difficult to work with. Scoreing and breaking works but the score line has to be fairly deep. A coarse blade hacksaw also works and was my preferred method. For cleaning up edges--a wood rasp worked great.
Tim
Tim
Rod Doors sells some Mongo size velcro pieces. They work very well for holding panels in place. And, as far as warping, I would think that the wood is far more likely to warp than the plastic. Look on the Rod Doors website for ideas. They show how you can glue foam cut into designs to the abs. Then you can apply the material over that for a custom look. Good luck, Jag
ABS won't warp unless it gets extremely hot and has strain on it such as fabric pulled very tight over one side of it. If it is securely attached it won't go anywhere. I personally prefer attaching with the push in plastic rivets where fasteners would be visable, and/or trim screws where they won't be noticed. Look at new car's plastic panels for fastening techniques. I've never had good luck with velcro, maybe other's have. I find it bulky if it's heavy enough to work and with getting it to stick to the surfaces better than to itself.
AX is right. Velcro usually does not do a great job. But the mondo size that Rod Doors sells is exceptional. Rod Doors door panels are not just flat pieces of ABS. The edges are curled so that the panel has about 1/8" space behind it. The two pieces of velcro, when joined together, are about the same thickness as the space. So, when you attach the velcro pieces by slapping the panel into place, it holds the panel edges flush to the door for a very finished look. Somebody making their own could glue 1/4" wide strips all around the perimeter to creat the same hollow area behind the panel so that the velcro can be used. Good luck, Jag
#28
#29
How is it attached to the panel and the metal? All the glues, double stick tape and self stick I've tried pulled off one or the other when I tried to remove the panel again. I'd love to find some that worked since the shock adjustment on the rear of the Miata is behind the ABS trunk panels so I'd like to get some that would allow me quick access when I need to make an adjustment at a race.
#30
Ax
I actually cleaned the doors where the hook side of the Duolock sticks with alchol and steel wool befor applying the panels. I can't tell you how it would work with several cycles of removal and replacement as that was not my application. I can however tell you the stuff has adherred to the doors extremely well and is a nice tight fit. It might just work for the Miata.
Tim
Tim
