Multiple questions....
Old Feb 7, 2006 | 08:59 PM
DJOHAGIN's Avatar
DJOHAGIN
regarding interchange. Are door seals and door window seals different between a 1983 F series and a 1995 F-series? Are the frames the same between a 83 and 95? Will a van, years in mid 80's, 9 inch rear end bolt up in a 1983 ford truck? Thank you for any replies.
Old Feb 7, 2006 | 11:01 PM
Larry_the_handyman's Avatar
Larry_the_handyman
The rear ends are interchangeable. I'm not sure about the window seals. The door seals will work even though the profile is slightly different. (I think) Either way, the door seal will press on just fine.
Old Feb 8, 2006 | 08:11 AM
Sycostang67's Avatar
Sycostang67
The frames should be interchangeable as well, I know you can swap a 95 cab onto an 83 frame. Just make sure the frames were from the same cab configuration.
