4x ques
Old Feb 7, 2006 | 08:16 PM
amikeinkc's Avatar
amikeinkc
4x ques
I see that 4x4's had an optional front axle positraction in '72. I don't understand what good it would do. In 4-hi with hubs locked in would positraction be of any help?? If hubs were not locked in, wouldn't be of any help either???? How fast can you drive in 4-hi with locked hubs. Can I assume it is not a good idea to drive in 4-hi with hubs not locked in. I saw one for sale that was stuck in 4-hi. Owner said he drove around with hubs not locked so it was ok????? BTW starting to put together my '72 250 4x that I took apart last fall. Reman short block, rebuilt t/c etc. My first one so be on the lookout for my questions. Thanks
Old Feb 7, 2006 | 10:09 PM
thesprocket26's Avatar
thesprocket26
Positraction action lets both tires spin at the same time to allow for more traction instead of one wheel spinning when you get stuck. I have driven around 45mph with my hubs locked in hi on dirt no problem. Most people would want a locker in the front axle to get 100 percent positive traction.
Old Feb 7, 2006 | 11:31 PM
1972ford_f-100's Avatar
1972ford_f-100
a normal rear/front end allows the wheel with the least resistince to move faster, a posi-track allows both wheels to spin at the same rate ,making it harder to turn corners in normal driving
