Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
solvent cleaner fluid
Old Dec 25, 2002 | 04:15 PM
cajunbull61's Avatar
cajunbull61
What kind of cleaner do you guys run in your solvent cleaner and what type of filter do you use???:-X12 :-X12 :-X12
Old Dec 26, 2002 | 09:03 AM
theonlybull's Avatar
theonlybull
Old Dec 26, 2002 | 08:14 PM
Art's Avatar
Art
I use mineral spirits from the local hardware store in the partswasher that I built. I am careful not to create sparks near it, and keep the lid down when its not in use. It holds about 18 gallons and the solvent lasts pretty long before it loses its "cutting" ability. I designed into it a cascading system the fluid must follow before the fluid can reach the Little Giant pump. That helps most of the "stuff" settle out. After the pump, it all flows through a Luberfiner 750 filter (with the orifice removed) - talk about awesome dirt capacity!
Eastwood Co. advertises a water-based solvent, but I think it may be expensive and I have no experience with it.
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3467&.jpg
