Rough Idle and "Chugging"
Old Feb 6, 2006 | 09:45 PM
00blkexplorer's Avatar
00blkexplorer
Long time reader. First time poster. I recently bought a 2000 Ford Explorer not to long ago with 98k. Now it has 108k. But after a couple months of having the truck, I had to replace already 3 spark plugs in the number 5 cylinder. Last code I got was p0305, which is misfire in cylinder 5.
After replacing the spark plug, the truck runs fine. But its been already 3 months and the problem started again. I changed the spark plug again to no avail. I already changed the spark plug wires and all the fluids. I need some help please! I really like my truck but this is just strange. Thank you!
Old Feb 7, 2006 | 01:05 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
What does the plug look like when you pull it? Black and sooty by chance?
Old Feb 7, 2006 | 10:00 AM
00blkexplorer
the last time i saw the plug, it actually had a crack going right through the plug. right by where the actual spark happens. i dont remember if it was black or sooty. I think it was.
Old Feb 8, 2006 | 12:41 AM
CowboyBilly9Mile
If it's black and sooty that would imply rich. My first thought on that one would be a leaking injector.
If the insulator was cracked, my question is "do you have a problem with engine knock?"
*The color and condition of that plug will tell a story. One is being black, which means rich. Clean and nearly like new (assuming low miles) suggests no fuel or spark. A very light tan to slightly white is what you want to see. I'm a bit confused by the sequence of events but it sounds like you're lacking spark on #5 or there is an injector probelm on that cylinder.
Old Feb 8, 2006 | 05:19 AM
marragtop's Avatar
marragtop
Do you consistently get the p0305 code?
Race
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 1, 2016 03:36 PM
CelticDevilDog
2004 - 2008 F150
Aug 13, 2012 08:59 AM
cem1985
Feb 26, 2012 11:59 AM
DRM2004
2004 - 2008 F150
74
Feb 19, 2011 06:25 PM
