Alternator Help
Old Feb 6, 2006 | 06:00 PM
kdmcinnes's Avatar
kdmcinnes
Alternator Help
Brand New Two wire Alternator not charging Battey, I think the wire's are mixed up, But before I start taking it off, I would like to double check.
Any Help would be Appriciated.
Kyle
Old Feb 6, 2006 | 06:32 PM
Jag Red 54's Avatar
Jag Red 54
You can take it to an auto parts store and they will mount it on their testing machine to tell you if it is working correctly. My alternators have all been three or one wire. Never heard of a two wire before. Do you have the battery wire hooked up correctly? Jag
Old Feb 6, 2006 | 06:44 PM
kdmcinnes's Avatar
kdmcinnes
Not sure, Kinda what I was Asking, The Alt has two posts on the back, I am just not sure what goes where.
Old Feb 6, 2006 | 07:15 PM
kdmcinnes's Avatar
kdmcinnes
Here is what I got
Old Feb 6, 2006 | 07:20 PM
kdmcinnes's Avatar
kdmcinnes
From Harness Red to Alt (Top), Black to plug. Then I have a red from Plug to Alt (Bottom)
Old Feb 6, 2006 | 07:33 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Does one of the smaller wires go to a power source that turns on and off with the battery?
Old Feb 6, 2006 | 07:40 PM
57_ford's Avatar
57_ford
I see the problem. The red wire comming out plastic plug should hook to the battery not to ground. You may just be able to hook it to the main red wire on the back of the alt. The black wire should be hooked throu a warning lamp than to the ignition switch at the run term.
Old Feb 6, 2006 | 07:41 PM
kdmcinnes's Avatar
kdmcinnes
I belive that the red on coming out o the wilr loom goes to the ingnition, but I am not 100% sure I took pics and hooked it up like it was with the old Alt, but The post may be diffeent and no instructions came with.
Old Feb 6, 2006 | 07:44 PM
kdmcinnes's Avatar
kdmcinnes
So the red coming out of the plug then should be conected to the top post, and the other to the bottom?
Old Feb 6, 2006 | 07:52 PM
57_ford's Avatar
57_ford
The red wire comming out of the plastic connector should be hooked to the lug on the back were the other red wire is.
Old Feb 6, 2006 | 07:54 PM
57_ford's Avatar
57_ford
Both red wires should hook their.
Old Feb 6, 2006 | 07:55 PM
kdmcinnes's Avatar
kdmcinnes
O.k. So both red wires together on the same stud, and nothing on the bottom. Right?
I am just making sure I understand
Old Feb 6, 2006 | 07:58 PM
57_ford's Avatar
57_ford
Yes the stud.
Old Feb 6, 2006 | 08:00 PM
kdmcinnes's Avatar
kdmcinnes
O.K. I will give it a shot, Thanks for your patience.
Kyle
Old Feb 6, 2006 | 08:06 PM
Christopher2
Veteran: Navy
I am not familiar with this setup, whay are both wires hooked to the battery terminal? Also the black wire goes to the indicator lamp?
