Relay Going Bad???
Old Feb 6, 2006 | 02:40 PM
turbostroke's Avatar
turbostroke
Relay Going Bad???
Can you guys tell me what type of relay is located left of the ashtray and under the little cubby hole .. if you take the fuse panel cover off and look to the right you can see a few in there.. My problem is for about the last three months there is a crackling, scratching noise coming from under that area of the dash. It's intermittent and doesn't do it all the time but if I turn to truck off and just sit in the cab sometimes I will hear this noise and finally it did it enough to locate the area it was coming from. Has anyone had this issue or may know what it is??? 99.5 model year with 170,000 miles Truck still has all functions so is a relay on the way out?? HELP!!
