what parts are needed for a lift kit. i am thinking about building my own 2-3" lift kit. i know i need:
1. new shocks
2. new springs
3. maybe an add-a-leaf
4. spacers for the rear
what else do i need?...i have a friend that has the tools and the ability to weld and fabricate spacers and other metal parts...which parts can i make? please bless me with your knowledge...haha.
chris
what type of truck is it for? do you plan to offroad with it, or just for looks? if it is just for looks, i would just get a body lift, and spend 300.00 to get something that isnt going to fail, rather than try to make your own stuff. however, if you want a suspension lift, then you will need a track bar bracket and longer sway bar links, or drop down brackets for it as well. and if you have a 2 piece driveshaft, then you will need a carrier bearing drop bracket also. i may have forgotten something, so maybe someone will chime in too.
it is a 93 f250 2wd...i want it for SLIGHT offroading but i also am going for the good look that comes with all lifted trucks...plus i am going to put bigger tires on and i haul a lot and don't want them to rub.
chris
