Ford Explorer Windows
Old Feb 6, 2006 | 12:07 PM
tamaninij's Avatar
tamaninij
I've picked up some great info from this forum, but this is my first post. I have a 1999 ford explorer that has a problem with one of the rear power windows. I can get the window to go up and down from the drivers window control, but the person sitting in the rear seat is only able to get the window to go down, but not up. Would it be the switch on the rear passenger door. I'm assuming since it works fine from my control, its not the motor. Also one of the other windows wobbles when it goes down. It seems like a lot of minor problems are starting to surface. Any help would really be appreciated.
Old Feb 6, 2006 | 12:17 PM
deltasoft's Avatar
deltasoft
yes change the switch for that door that has the window problem. somethings you can even fix the switch if its some minor issue. although you can just change whole switch...ford sells it for about 70-100 buckz per switch
Old Feb 6, 2006 | 12:22 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
Maybe the guys in the Explorer forum would have the answers as well ?
Old Feb 6, 2006 | 12:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Feb 7, 2006 | 06:50 PM
tamaninij's Avatar
tamaninij
Thanks for your help. I'll play with it this weekend.
