Sponsored by: Kumho
Synthetic Brake Fluid
Old Feb 6, 2006 | 01:55 AM
Silverrv's Avatar
Silverrv
Question Synthetic Brake Fluid
Hey you all I need a little help..
I am rebuilding my brake system and want to know what the word is on Synthetic Brake Fluid...???
Is it any good.?? Does is meet or exceed DOT3 spec..??
Any input would be great...
Old Feb 6, 2006 | 09:54 AM
beartracks's Avatar
beartracks
I've used it for years. It's rated DOT-5. It wont eat paint or attract water to corrode the hydralic system. I am told it will aerate if used in extreme conditions or with ABS.
Old Feb 7, 2006 | 12:51 AM
Silverrv's Avatar
Silverrv
I was in an Auto Parts store today and Preston has some out that says it is DOT3,DOT4 compatable.
What is the difference in these DOT numbers..??
Old Feb 7, 2006 | 01:11 AM
ford390gashog's Avatar
ford390gashog
DOT 5 from what i read is not to be used in ABS systems. also to use DOT 5 in place of DOT 3 requires 100% new components. the slightest amount of DOT 3 will react with it and it eats rubber. i
Old Feb 7, 2006 | 06:57 AM
kotzy's Avatar
kotzy
DOT 5 fluid is silicon based and no way compatable with dot 3.
Previous poster correct Dot 5 does not wick moisture. While I'm
not up on the sythetic dot 3 fluids I would guess that is the reason
for their development. I think if you search the net you could find
the rating difference between them. Alot of it has to do with boiling
points of the fluids. Me I've been exposed to dot 5 silicone fluids
at a former employers, I could not see much gained in normal application
for the greatly increased cost. I still use the old dot 3 fluids in my stuff and
have had no problems.
Old Feb 7, 2006 | 07:09 AM
The SnoMan's Avatar
The SnoMan
Like the above poster said, if it is silicone based, it is not at all compatable with. Not all DOT 5 fluid is silicone based though so it is possible to have a DOT 5 fluid the is DOT3/4 compatable. If it is glycol based like DOT3 and 4, it will get along but if it is silicone, you really need a new fresh system for it to work correctly. The DOT 5 standard does not mandate the use of silicone, it only basically states the specs of the fluid for tempature stabilty/boil point.
blue66tang95f150
Aug 11, 2015 10:33 AM
duffin
May 27, 2012 06:56 PM
jackassjeeper97
Feb 6, 2008 08:27 PM
1975Ford
Oil & Lubrication
13
Jan 4, 2007 11:31 AM
SmittyD
Apr 9, 2005 07:54 AM
