Boots...
About the hardware...depending on the mounts you have, EB1 mounts will have a steel sleve that goes through the bushing, then the bolt goes through that. Sometimes they supply a new EB1 stud mount for the upper mount that some trucks use. If your truck uses them you can either leave the old one in if its in good shape or replace it with the new one. If theres a stud mount you shoud have a cupped washer to go on top of the bushing and on the bottom of it too.
