Which Turbo Timer?
Old Feb 5, 2006 | 04:51 PM
John D's Avatar
John D
Which Turbo Timer?
I am looking for a Turbo Timer for my 6.0l
I have found all kinds out there to choose from, but not a lot of information on them and diesel engines, mainly sport tuners.
Are there any that I should definately stay away from?
Is there any option that I just shouldn't live without?
I have a 2003 f-250 with Edge and Attitude Monitor......
I have not seen any "plug and play" harnesses for my truck, do they make them, or will I have to put it in manually? If so How complicated?
Thanks
Old Feb 5, 2006 | 05:41 PM
Maxium4x4's Avatar
Maxium4x4
Good question, I am sure some will chime in. Some of us use remote start systems that feature a run time for the truck. I have Astro-Start installed in my truck and can walk away with the truck shutting down by time instead of temperature.
Old Feb 5, 2006 | 11:59 PM
DiscountPowerPrt's Avatar
DiscountPowerPrt
We have some listen on our website, but I think there might be a couple availabe that are not.
http://www.discountpowerparts.com/Online_Store/Alarms%20and%20Remote%20Starts/alarms_and_remote_starters.htm
Id like to get rid of mine and get the system on the bottom of this page. Its sweet, but my wife has Mod envy right now so I have to lay low for awhile. lol
I dont know why Larry hasnt placed the buy It now links on these yet....I guess I have to do everything cough cough. haha Give us a call we can hook you up.
724-462-3669
724-272-1539
Old Feb 6, 2006 | 09:24 AM
dsweger's Avatar
dsweger
When I looked at various "Turbo Timers" and "Turbo Minders", I decided that I could install a Remote Starte system and activate the cool down timer myself based on the Pyro guage when I shut it off. In addition, you get the benefit of remote start, and other features, on most systems. For another few dollars more (still less than most Turbo Minders), you can get a remote start system combined with an alarm system to help protect your "easy to steal" Super Duty.
You will probably spend less money on a remote start system, and have more functionality when you are done.
Old Feb 6, 2006 | 04:03 PM
Maxium4x4's Avatar
Maxium4x4
How could you go wrong with peace of mind and features for $240
Old Feb 6, 2006 | 04:08 PM
DiscountPowerPrt
Well the truck only has 10k miles on it and I have a SCT Innovative diesel tuner 4" straight pipes and Airaid intake. Oh and bullydog outlook monitor and I need Tires bad! Your right thought for the money that one system we sell does everything. I tell you what...give me a call and I can knock 30 bucks off then add shipping. Hell anyone from FTE can have that price. Part # 564T
Old Feb 6, 2006 | 04:13 PM
DiscountPowerPrt
you come up with your best price and I will try to match it.
Old Feb 6, 2006 | 05:00 PM
John D's Avatar
John D
How hard is this wiring nightmare to install?
Just to let you know. I have been a tank mechanic for the army for the past 18 years, so mechanic`n I can do.....BUT when it comes to electric crap, I can't hook up the DVD player to the TV without doing some cussin`!
I have been wanting the remote starter for a while, I have heard so many bad stories about them! Heck I got enough troubles already, I don't need to ask for more!
Is there a place that can install it for me?
MIdway, Georgia here
Old Feb 7, 2006 | 08:02 AM
dsweger's Avatar
dsweger
It depends on your definition of nightmare.....
You would end up with 12 - 20 connections to make depending on what features your system has, and how many of those features you want to work. Seven of those are the "high current" circuits that deal with the ignition, starter, and accessory circuits. The rest are "low current" circuits for things like the parking lamps, horn, door locks, safety interlock switch under the hood, system ground, tach signal, and brake pedal switch. If you add an alarm system to the package, there will be more......
The biggest problem for me was working under the dash. I'm not as small, limber and flexible as I used to be and the Bi-Focals are a serious handicap There are a lot of wires and connections to be made under the steering column. It gets crowded and is darn near impossible to make it a neat job. I worked and worked to make the install as neat as possible, and I'm not totally satisfied with that aspect, but I am not doing it over any more. It works fine and you won't see the messy wiring unless you stand on your head and look for it.
Do lots of research first, make sure you have the proper wiring diagram for YOUR truck. Door lock acuators are powered differently for trucks with keyless entry than the trucks without keyless entry. ( NOTE: Keyless entry trucks are easier.) On the 6.0 diesels, you cannot use the wait to start signal, you just have to program a ten second delay in the starter to allow the glow plugs to do their thing. You can find copies of the Install manuals for the Ford Remote Starter on the Internet. Although not all of the connections will be identical, many will be and it will also help you find the wires in the truck. I say again, MAKE SURE YOU ARE USING THE CORRECT DIAGRAM FOR YOUR TRUCK. Make copies of the wiring diagram for your starter and make notes on the paper as to what wires get connected to what color and what location. Plan your work ahead to make life easier. Allow plenty of time to do the job, and if you have a buddy who likes to help with that kind of stuff, have him there. You'll need someone to cuss at when you are stuck upside down under the dash and just can't get your hands wher you want them. Finally be prepared to make minor changes to your plan when you find things don't fit just like you thought they would.....
