Correct Valve body for C6?
Old Feb 5, 2006 | 07:08 AM
Todd Dietz's Avatar
Todd Dietz
Question Correct Valve body for C6?
My 84 F250 4X4 / 6.9 has a shift kit in the valve body that is damn annoying to say the least. Is the valve body for the C6 that is in this truck any different from a standard C6? My friend it might be different from a standard C^ because it is diesel. I want to get a replacement valve body, one that does not have a shift kit installed in it.
TIA
Todd
Old Feb 5, 2006 | 07:52 AM
mistakenID's Avatar
mistakenID
A shift kit generally only improves the shift. As in, it will make a more positive, quicker shift. It may change the rpm of each shift also but is a considerable improvement over a trans sliding into each gear. What is the trans doing that is so annoying?
The valve bodys will interchange, but the one for diesel is slightly different internally. I do know there is an upgrade kit that can be installed in a gas C-6 that changes it to the diesel trans. It's nothing more than a few springs, check *****, instructions on enlarging a few passages.
Old Feb 5, 2006 | 07:59 AM
Todd Dietz's Avatar
Todd Dietz
Exclamation Correct Valve body for C6?
The annoying things it is doing is SLAMMING into second gear, and downshifting everytime you step on the pedal even a little bit. It drive like a hunk of s%#t! LOL So what do I need to ask for when searching for a "normal" valve body? Can I get one from a tranmission core place, or should I go through a trans shop?
TIA
Todd
Old Feb 5, 2006 | 08:39 AM
DeepRoots's Avatar
DeepRoots
is the vrv and vaccum pump up to snuff?
my truck also downshifted easily, I took the kickdown rod off, and it looked a lil bent, I i re-bent it, and it only downshifts now if I floor it.
Old Feb 5, 2006 | 09:11 AM
tjc transport's Avatar
tjc transport
i ain't rite
you need to adjust the downshift rod. it should only move at almost full throttle. a shift kit adjusts the upshift sequence, not the downshift. and it is better t have the trans shift "hard" than a "soft" slip into gear. with a diesel that slips into gear, it will tear up the clutch packs in the trans, due to the excessive torque of the engine
Old Feb 6, 2006 | 10:40 AM
mistakenID's Avatar
mistakenID
The trans might even have the wrong vacume modulator. The other replies are correct on the kickdown rod adjustment.
CTC01
May 12, 2014 09:52 PM
Todd Dietz
Oct 28, 2006 12:59 PM
tcinks
Oct 5, 2003 02:02 PM
