www.ford.com
Old Feb 5, 2006 | 06:16 AM
ford390gashog's Avatar
ford390gashog
www.ford.com
is it just me or is the www.ford.com website hard to use? i wanted to build a f350 truck but they only let you build the f 250. whats with that? then i found a backdoor way to build a f350 yet it lists no dual wheel option. before they redid the website last year it was easy to use. now it is really hard to use.
Old Feb 5, 2006 | 07:02 AM
killaford's Avatar
killaford
i was thinking the same thing first time i used it.
Old Feb 5, 2006 | 07:59 AM
boxcar1974's Avatar
boxcar1974
use www.fordvehicles.com instead.
Always works for me.
Old Feb 5, 2006 | 03:04 PM
polarbear's Avatar
polarbear
Remember the dual rr wheel thing is a model, not an option.
Old Feb 5, 2006 | 08:42 PM
HeavyAssault's Avatar
HeavyAssault
http ://www3.forddirect.fordvehicles.com/Dispatch.jsp?makeTransition=ToTrimSelect&__action2 =&.CurrentState=HomePageFlash&processModel=1&selec tModel=2006+F-350&statetoken=
Cut and paste, remove the space after the http.
Old Feb 6, 2006 | 08:54 AM
1956MarkII's Avatar
1956MarkII
We're often told that Ford monitors this site. If there was ONE thing I would wish they would take from here, it's this: FIX YOUR EXTREMELY USER UN-FRIENDLY WEBSITE!! No one can follow "The Way Forward" if you continue to support a website that customers can't decipher, and salespeople have to refer those customers to other websites (like carsdirect.com) in order to accurately build and price their vehicle.
Old Feb 6, 2006 | 04:03 PM
ford390gashog
so dual wheel is a model? it used to be setup i could click f 350 then select dual rear tires and add the 4.10. so if i want to build a dually model where in the heck do i go? i think the chevy website is easier to use.
Old Feb 6, 2006 | 04:20 PM
1956MarkII's Avatar
1956MarkII
Ford uses body codes to differentiate between SRW and DRW, as well as different preferred equipment groups for trim levels. For instance:
Body Style:
F350 2WD SRW Crew Cab: W30
F350 4WD SRW Crew Cab: W31
F350 2WD DRW Crew Cab: W32
F350 4WD DRW Crew Cab: W33
Trim levels:
F-350 XL SRW: 610A
F-350 XLT SRW: 617A
F-350 LARIAT SRW: 618A
F-350 XL DRW: 620A
F-350 XLT DRW: 627A
F-350 LARIAT DRW: 628A
Add in 3 interior colors, 12 exterior finishes, 3 seat styles, short or longbox, and a couple of hundred options, and it REALLY starts to get fun!
Old Feb 6, 2006 | 09:55 PM
polarbear's Avatar
polarbear
Holy crud that's lame! I just tried to build that thing myself.
Old Feb 7, 2006 | 07:17 AM
bgrover's Avatar
bgrover
Yep the site is a real PAIN! But the following will hopefully get you going.
  1. Go to www.fordvehicles.com
  2. Click on the Build and Price your Ford in the lower left corner.
  3. Click on Trucks at the top of the screen.
  4. Choose the F350 from the list of trucks.
  5. Choose your trim level (xl, xlt, lariat, king ranch).
  6. Enter your zip code and click Choose Preferences
  7. Now start choosing what you want - The DRW is the 4th set of options.
Now you can continue and add the rest of what you want into the truck. Fun fun!
