5" or 6" exhuast
Old Feb 15, 2006 | 12:22 AM
  #31
DiscountPowerPrt's Avatar
DiscountPowerPrt
You can check out our site http://www.discountpowerparts.com/On...ford__page.htmor Dr.Performance @
http://drperformance1.reachlocal.com...drperformance1
It is a quality product...they also have injectors and a trailer brake controler. They have a Nitro Flash programer that is very popular for the Duramax. If you have any questions please feel free to call.
Old Feb 15, 2006 | 11:56 PM
  #32
Industrial_dude's Avatar
Industrial_dude
Right now im running a mbrp 4" turbo back exhaust on my excursion and its falling apart im getting horrible turbo drone and exhaust leaks everywhere. I dont blame the quality of the exhaust i think its my fault for off roading to much, anyway I need a new one but I dont know what to go with. Might think about duals but dont know if anyone makes duals for the excursion, and i dont know if it would even fit because i double shocked the rear and the shocks get in the way i dont know what to do anybody have any advice? thanks
Old Feb 15, 2006 | 11:59 PM
  #33
DiscountPowerPrt
I think one problem with the duels on th Ex is the fuel tank. Its in the rear driver side corner is it not? I know Larry wants them on the shop Ex.
Old Feb 16, 2006 | 12:03 AM
  #34
Industrial_dude
Yea that fuel tank ruins the whole show in the exhaust department with the ex. I need ideas.
Old Feb 16, 2006 | 12:23 AM
  #35
DiscountPowerPrt
Im sure it could be done with a little ah.....engineering
Old Feb 16, 2006 | 12:32 AM
  #36
Brian460's Avatar
Brian460
Don't know about the MBRP but, magnaflow duals have a clearance issue also if you have a pickup with a gooseneck hitch.
Old Feb 16, 2006 | 07:36 AM
  #37
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
The MBRP dual system is not advertised for an Excursion. They have an Excursion specific system, but it is not duals. So your going to need to do some creative engineering.....and I always recomend a welder when feeling creative. If you were in the PA area I would tell you to stop by the shop and I would take care of it for you...for the price of a six-pack of beer! Good luck dude!
Old Feb 16, 2006 | 09:03 AM
  #38
Industrial_dude
thanks trkpuller! unfortunetly i just ran into another problem.
Old Feb 16, 2006 | 09:25 AM
  #39
fordtrkpuller
FTE *******
Remember, if you have a MIG, a TIG, a Plasma Cutter, a set of torches, and a roll of duct tape....you can fix anything but a broken heart.
Old Feb 20, 2006 | 10:05 PM
  #40
RyanF's Avatar
RyanF
I have a question about my 4" bully dog exhaust. I was just wondering if it could cause me any problems.
Old Feb 21, 2006 | 06:12 AM
  #41
fordtrkpuller
FTE *******
Problems with what? We put a 4" Bullydog under our 05 F-350 we run here and it was a direct fit, no problems, no torch, no welder........it just fit. The down pipe was a real challange to get in, but I have a tool called a "Pat"...its a 6' 3" 260 lb man that can lift a car if he chooses.....and...well....I used my Pat tool to get that damn downpipe thru. Its tight. Other than the tight fit getting the downpipe in, its a non issue completely. Bullydog does a nice job on the exhaust, and its not priced like its gold lined.
Old Feb 21, 2006 | 09:46 AM
  #42
RyanF's Avatar
RyanF
I was actually wondering if the exhaust could cause any harm to the engine or other parts such as the turbo.
Old Feb 21, 2006 | 09:54 AM
  #43
fordtrkpuller
FTE *******
Nope. It will lower your EGT's and HELP the engine live healthier and happier for a longer time. What will hurt your engine is stock exhaust and intake on a truck being pushed hard at its limits. There are numerous bone stock 6.0 PSD trucks set up as ambulance or tow truck applications that have taken out engines from the hard loading and heat. Your new exhaust is a good thing from every point of view.....except maybe the guy in the car with the tailpipe pointing at his window as he is vibrating with your exhaust hammering his window....lol....
Old Feb 21, 2006 | 12:52 PM
  #44
RyanF's Avatar
RyanF
So would you recommend putting an intake on the truck as well.
Old Feb 21, 2006 | 01:14 PM
  #45
flyMike's Avatar
flyMike
4" vs. 5" exhaust
Is there any potential for damage using a 5" exhaust on a truck running betweem 400 and 450 HP? I have a 5" exhaust as a recommendation from the shop I had some mods done...but afterwards, I saw/read that a 5" exhaust should be run on trucks running greater than 450HP. Am I still getting enough back pressure? ANy other concerns? I am thinking about going down to a 4" exhaust...yes it is from turbo back...Thanks.
Oh, by the way. It's a '04, F350, fully loaded, long bed, full sized cab, Harley version...sweet truck.
