how many use electric fan
Old Feb 4, 2006 | 02:36 PM
1949f1's Avatar
1949f1
it look's like i may be useing an electric fan on my 49, the radiator is going to be close to the water pump . i went by the measerment that cpp gave me on the engine mount's. the valve cover's are about one half inch from the fire wall. anybody else useing an electric fan on their truck ? thank's
Old Feb 4, 2006 | 03:09 PM
AXracer's Avatar
AXracer
Many of us use an electric fan. More efficient and less hassle than mechanical one, can be thermostatically contolled.
Old Feb 4, 2006 | 07:33 PM
Randy Jack's Avatar
Randy Jack
I use one for the 351C in my 56. It is a 16" 1600 cfm straight-blade unit, mounted directly to the stock radiator without a shroud and thermostatically controlled. Works great. 100+ degree weather and stop-and-go traffic are no problem.
If and when I add AC, I will go to a stronger (2000 cfm) S-blade electric fan.
Old Feb 4, 2006 | 09:23 PM
46yblock's Avatar
46yblock
Mine is a similar setup to Randy Jack's. Mounted direct to radiator, no shroud, 2700 cfm, 292 motor. Manual on off switch.
Old Feb 4, 2006 | 09:49 PM
fiftyfourdf100's Avatar
fiftyfourdf100
I'm putting fan(s) on my 54 F100 with a 351W without a shroud. I just put a set of dual fans on an 83 Cutlass, and it runs a lot cooler than with the clutch fan. On my fans, I have a 3 position switch, it has ON(auto with thermostat), OFF, and FULL ON(on all the time no matter the temp). It is the same way we put an electric fan on my buddy's 88 Fox Body Mustang drag car.
Old Feb 4, 2006 | 10:48 PM
Col Flashman's Avatar
Col Flashman
2 diagonally mounted 1,200cpu fans on my 4 core desert radiator, as there wasn't enough room to mount the original fan.
Old Feb 4, 2006 | 11:44 PM
packrat56's Avatar
packrat56
I have a basic model from summit, its sooo much better than the hard mounted one on my 302. Kind of noisy when it comes on, likely my mounting?
Old Feb 5, 2006 | 09:55 AM
hotrod48's Avatar
hotrod48
I have a 16" Spal on my 48.
hotrod48
Old Feb 5, 2006 | 10:23 AM
OilLeaks's Avatar
OilLeaks
I have an electric junk yard fan out of a 70s Dodge van cooling my stock but recored flathead radiator. It's getting tired so when I complete some of the work and actually get to drive it again I'll probably put a Spal or some more modern variant on it - I think it's a 16 inch unit and it worked better than the original fan on the flatty. It's a little noisy but too obnoxious.
OilLeaks
Old Feb 5, 2006 | 10:27 AM
screwloose2's Avatar
screwloose2
49 f1
I have a 18" lincoln mark8 fan ( with shroud) with a variable speed controler . works like a charm , it will suck in the neighbors cat
Old Feb 6, 2006 | 09:58 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Let me know the next time your fire 'er up. I have a few cats in my neighborhood I'd like to send your way...
Vern
Old Feb 6, 2006 | 07:09 PM
OilLeaks's Avatar
OilLeaks
Now Vern that's just not nice........besides all the cat gook would be real hard to clean offa nice Ford engine!
Leaks
Old Feb 6, 2006 | 08:52 PM
John - NNY's Avatar
John - NNY
Vern
HEY! I like cats . . .
. . . they kinda taste like chicken.
Old Feb 7, 2006 | 01:38 PM
Dan Tenn's Avatar
Dan Tenn
fan?
Leaks
Not sure about a nice ford engine, but I can tell you how hard it is to clean cat off the engine of an 80's Grand am. I can elaborate if the need arises.
Old Feb 8, 2006 | 07:30 AM
GreatNorthWoods
Eewwwww!
Vern
