I have a 94 inline 300 and I need the fire order for the distibuter. I know ive seen numbers like 1-4-3-2 but I dont know what it means. PLEASE HELP!!! If you have a diagram that would be nice, I dont have my manual for my truck.
those are your cylinder numbers your missining 2 numbers 5 & 6
??? I dont know what that means. I just made an example. Thats not an actual firering order.
the number 1 cylinder is the closest to you when you lift the hood followed by #2,#3,#4,#5,#6
your distributor cap should have a #1 on it that is where your first wire goes
on your intak should be the firing order they go counter clockwise on your distributor cap
your first wire goes on #1 on your dis. cap then to the first spark plug, the second wire goes to the left of your 1st on your dis. cap and to the 5th spark plug, the 3rd wire goes to the left of your 2nd wire on your dis. cap and to your 3rd spark plug ETC.ETC.
