Pics or Microfiche
Old Feb 3, 2006 | 10:20 PM
rsjohns2's Avatar
rsjohns2
Pics or Microfiche
Does anyone know of a sight online that I can go to find pics or a microfiche of the steering setups on 67's and up? I have access to a power steering box off of an early 70's pickup and some other things as well. It has been awhile since I have worked on these models and I can't remember how the steering actually worked on my '67.
Thanks
Scott
Old Feb 4, 2006 | 12:49 AM
MR_J_DAHMER's Avatar
MR_J_DAHMER
moog chassis book
Go to your local auto parts store that still has catalogs (napa) Ask to see the older car and truck Moog Chassis Parts book. It has exploded parts pictures with part numbers. Same part number,,fits, different number,,no fit.. Hope this helps...good luck hunting DAHMER
Old Feb 4, 2006 | 04:57 AM
jowilker's Avatar
jowilker
Scott, What do you need to see? The power gear uses the same three holes as the nonpower.
John
Old Feb 4, 2006 | 06:42 AM
rsjohns2's Avatar
rsjohns2
Thanks guys, What I am after is where does the steering box go on the '67? In front or behind the engine crossmember? I am picking up the truck today but it doesn't have the gear box and the guy that I am getting it from has the power unit but it mounted behind the crossmember. I just want to make sure before I buy something that isn't going to work. He says it will work but I'm not positive yet.
Thanks
Scott
Old Feb 5, 2006 | 06:00 AM
jowilker's Avatar
jowilker
Scott, There is only one set of three in a triangle holes on the chassis for the gear to fit. I think it is behind the member with the pitman pointing forward.
If you get a power gear you will have to have a power column to match.
John
Old Feb 7, 2006 | 12:33 AM
MR_J_DAHMER
John
On another web site it stated that you only have to loosen the bolts under the dash that hold the steering collum, and the lower pinch bolt,then pull the collum up as needed to connect to the p/s box. The wheel will be 2 or 3 inches closer to you, (and rubbing on my beer belly, I am 6 feet 2, 285lbs). Anybody know for sure? May be worth a try (if you are skinny enough) and don't mind a NASCAR style wheel. DAHMER
Old Feb 7, 2006 | 06:34 AM
jowilker's Avatar
jowilker
Jeff, Think about it, if you add between 2-3 into the total link under the hood, how will the colum bolt back to the dash.
not gonna happen
You have to swap the proper shorter column with the power gear.
John
