Fuel Pumps
Old Feb 3, 2006 | 10:19 AM
cowboyupo6's Avatar
cowboyupo6
Fuel Pumps
I have a 1990 ford f150 with dual tanks my rear fuel pump hasnt worked for about 4months. Last week i thought my front fuel pump finally went out so i went and bought a new fuel pump and put it in the rear tank. tried to start it an nothign happened just cranked. checked for spark check out, then i replaced the fuel relay still nothing, then i was messing with the toggle swith and there was a jumper jumping across two wires and shook the wires alittle bit and turned my truck on to use the code tester and i heard my fuel pump kick on.... it started right up but it was on the front tank switched tanks and it dies. i have gas in both tanks... i also put a voltmeter and test light on the plugs of the fuel pumps and dont get anything on the rear... any comments will help thanks
Old Feb 3, 2006 | 10:33 AM
subford's Avatar
subford
Here is a Diagram of the system, I do not know what the jumper jumps from what to what. Also the toggle switch, what color wires do they go to.
Old Feb 3, 2006 | 12:22 PM
cowboyupo6's Avatar
cowboyupo6
i think its jumping red and blue.... it fell it feel out but it didnt change anything
