General Automotive Discussion
94 chev idle adjust
Old Feb 3, 2006 | 10:08 AM
beartracks's Avatar
beartracks
94 chev idle adjust
Anyone know if there is a way to increase the idle speed on a 94 Camaro V6? It seems to be computer controlled but vibrates at idle (I hate V6's) unless you give it a little gas. It's been through from A to Z on the tune up etc.
Old Feb 3, 2006 | 11:48 AM
balddave's Avatar
balddave
No idle adjust on tha chevy. You can turn any adjustment screw it has only to have the computer override it.
May want to check the timing.
Old Feb 3, 2006 | 12:03 PM
Zane M's Avatar
Zane M
balddave beat me to it. If everything else is up to snuff, it might just be a timing issue.
Old Feb 3, 2006 | 03:32 PM
Desperado82's Avatar
Desperado82
If you did a normal tune-up and only did plugs, wires, cap and rotor. You may need a scan of the system (not a code reader but scanner). You may have a bad IAC or the TPS may be off! Also the injectors may need cleaned/replaced. You may have a compression ratio difference causing the poor idle. You need to find the problem rather than turn screws on chevy FI vehicles.
Old Feb 3, 2006 | 03:33 PM
Desperado82
Also you may want to go to chevytalk.org for more info in Chevy!
