85 np 208 into 79 bronco questions.
Ok, I've got several options here, but they all need answers first before the big swapfest. 1. 85 f150 w/man. shift 208 behind aod would go into 79 bronco behind C6. driveshafts not a concern. 2. 89 f150 Bw1356 behind m5od would go into 85 f150. The problem here, is the tunnel covers. The 89 bw1356 shifter is on the left side of the hump, whereas the 85 f150 shifter is on top of the hump, which looks close to the same as the 79 bronco. What tunnel covers could I use? Anyone use a 73-79 C6 cover on a 80-86 f150? Are the floor dimensions and angles the same? Just hoping to get a little input, thanks.
sharker98
10-19-2003 07:40 PM
ddestruel
05-09-2001 06:49 AM
