Weird slushing sound
Old Feb 2, 2006 | 08:17 PM
ChronGen's Avatar
ChronGen
sometimes when i fire up my truck in the early mornings, there is a what appears to be a sound of moving water or something slushing around for a breif moment. it sounds like it's coming from somewhere on the passenger side of my 1990 F250 460ci. Anyone ever heard of this?
Old Feb 2, 2006 | 08:24 PM
frederic's Avatar
frederic
Are you sure it's not the fuel in one of your fuel tanks?
Old Feb 2, 2006 | 08:55 PM
quicklook2's Avatar
quicklook2
low on coolant and heater core sloshing because of air?
Old Feb 3, 2006 | 12:40 AM
lv2race's Avatar
lv2race
Sounds like air in the heater hoses, every now and then, you will hear water squirting into the core. Disconnect heater hose, raise above core level, and fill with water.
Old Feb 4, 2006 | 01:32 PM
ymurf's Avatar
ymurf
mine has been doing that for a year now..gona try that.
Old Feb 4, 2006 | 03:06 PM
924x2150's Avatar
924x2150
I think my heater has made sloshing sounds every year I have owned it. I don't think I have trapped air, or other problems either. My heater is working very well, there are no leaks, and my radiator and reservoir levels haven't gone up or down for months. I do believe it is the nature of the beast.
The coolant is being forced thru many tiny passageways, I don't thing you could move that much coolant and keep it perfectly quiet. My theory is that the coolant is cavitating as it is forced thru tight holes and passages, anotherwards, gas bubbles are forming due to the swirling motion of the liquid.
Old Feb 5, 2006 | 09:42 PM
gov2mod's Avatar
gov2mod
All I do on my Broncos and F150 is to remove the upper end of the small coolant hose at the throttle body. This is the highest point in the coolant system. A few seconds after you disconnect it the air will stop and the coolant will start to flow. Reconnect it and you are done.
