died and wont start?
Old Feb 2, 2006 | 01:22 PM
powersmoker's Avatar
powersmoker
i have a 97 psd that died going down the road. i have had all wireing replaced 4mths ago, when i lost idms. i checked codes and found only exhaust press. and idm failure. so i replace idm and still same code and wont start. please help
Old Feb 2, 2006 | 01:24 PM
1997F-350's Avatar
1997F-350
your getting an idm code now or then?
possible idm again, cps or fuse 22
Old Feb 2, 2006 | 01:31 PM
powersmoker
i had idm failure before and after i replaced the idm. i checked #22 and good. what is left?
Old Feb 2, 2006 | 02:19 PM
helpfulguy's Avatar
helpfulguy
I have a 95 and the same thing happened to me. the wires going to the kill solenoid had gotten soaked with diesel and the insulation had split and let the wires touch just enough to short so the solenoid would not open or close (which ever it is supposed to do i really don't know). when i replaced the wires it started right up again. i could also move those wires around some before i replaced them and it would start and run until vibration brought them back together. hope this helps.
Old Feb 2, 2006 | 08:56 PM
powersmoker
i have just checked that and they were melted to gether but not touching wire but i will replace it now anyway just to make sure i dident miss anything, thanks.
Old Feb 3, 2006 | 02:00 PM
powersmoker
i replaced the wireing and it still wont start, i also did a lift pump and inj pump. any more ideas
Old Feb 4, 2006 | 02:33 AM
rockyrider's Avatar
rockyrider
I'm posting a link to previous thread on this subject, hope it helps.
Have you checked your oil? Obvious but oft over looked, and will certainly cause no start.
https://www.ford-trucks.com/forums/s...d.php?t=441839
Old Feb 4, 2006 | 11:06 AM
DaBigTow's Avatar
DaBigTow
That is a typical CPS (camshaft position sensor) failure response; sudden death on the road.
Old Feb 5, 2006 | 05:19 PM
powersmoker
its alive believe it or not the lift pump was bad. after just throughing parts at it i figured meens im in here i will replace it and found the pushrod stuck in the pump. thanks for all the input.
{just woundering if any one could tell me why that would give me a idm failure code}
