Blackstone oil Analysis
Old Feb 2, 2006 | 10:31 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Question Blackstone oil Analysis
I was just wondering how many of you have had one done. I just sent in my first sample so I am curious as to what kind of info you get back. Seems like a really good deal to know what is going on inside your engine. Feedback anyone?
Old Feb 2, 2006 | 11:32 AM
HeatStroked's Avatar
HeatStroked
I've been sampling and semding to Blackstone for over 3 years now. Great preventative maintnence IMHO.
Excellent reports and baseline comparisons with like PSD, mileage, etc.
Old Feb 2, 2006 | 01:13 PM
PSNut's Avatar
PSNut
Switching to Blackstone myself...i agree with Heat...great PM idea.
Nut
Old Feb 2, 2006 | 01:29 PM
cgl's Avatar
cgl
Been doing it for over two years myself. They recommended I run up to 6500 miles. My engine bearly wears using Delo 400!
Old Feb 2, 2006 | 01:59 PM
ColtM4's Avatar
ColtM4
Been doing it too for about 2 years. Just switched to Delo from Rotella, no results yet, but did notice truck ran quieter with Delo. Truck seems to like Delo best, followed by Rotella, then Delvac 1300. I sample because I'm paranoid about air box leak and "dusting" my engine.
Old Feb 2, 2006 | 03:49 PM
rufaast's Avatar
rufaast
3yrs here, they have always provided very good information
Old Feb 2, 2006 | 04:01 PM
PSNut's Avatar
PSNut
That's probably because Delo contains a Molybdenum disulfide additive.Great stuff! Does a lot for your engine. Clean oil also has that quieting effect beacuse without all those large clumps of carbon it flows smoother. HEUI injectors don't
complain as much!
Check out this article on MD: http://www.bobistheoilguy.com/moly.html
Nut
Old Feb 2, 2006 | 07:28 PM
Powerstrokedlariat
I see, looks like a lot of you use it. How often do you recommmend sending in a sample? quarterly? yearly? every oil change? (spendy, but less than $10k for engine!)
Old Feb 2, 2006 | 08:14 PM
cgl's Avatar
cgl
... How often do you recommmend sending in a sample? quarterly? yearly? every oil change?
I did 4 consecutive oil change samples to establish my engine's baseline. Now i'll probably do it every third oil change or so, just to make sure my engine is still doing good.
...(spendy, but less than $10k for engine!)
At $20 a sample (you can get them cheaper if you buy bulk up front, 10 i think?).. A LOT less!!
Old Feb 2, 2006 | 08:20 PM
PSNut's Avatar
PSNut
A good friend of mine just had to replace his engine (gasser)because of antifreeze getting in the oil. If he did UOA's he would have detected it.
Nut
Old Feb 3, 2006 | 01:43 AM
SpringerPop's Avatar
SpringerPop
Thanks for the reminder. I've got 3K on the new bypass system and it's time to find out whether the Delo is holding up. Gotta pull a sample. Something to do Saturday.
Blackstone for the oils, Polaris for the coolant.
This brings up a related subject:
What do you tell the clerk at the post office when they ask "What's inside the package"? Of course, they can read that it's going to a "lab".
I just smile and say, "A specimen".
Pop
Old Feb 3, 2006 | 02:07 AM
ford390gashog's Avatar
ford390gashog
i use either blackstone or butler labs. butler labs has the better testing equipment and is setup to test for antimony.
Old Feb 3, 2006 | 02:10 AM
Tailspin's Avatar
Tailspin
Being from Canada,Eh!!! How many Kilometers do you fellas think i can go between engine oil changes on my 2000 PSD 165000Km on the ODometer, with mininmal towing and mainly hiway driving? Most guys here are doing oil and filter at every 5- 6 thousand Kilometers! Looks like i may go up to maybe 7500Km Safely. Maybe a shop here can do a analysis?
Old Feb 3, 2006 | 02:28 AM
SpringerPop
Hog,
What would antimony tell you that tin wouldn't?
Pop
Old Feb 3, 2006 | 04:10 AM
ford390gashog
well some oil makers are using additives which show up as coolant in the oil. the butler test goes further and can break those additves down into their chemical properties and tell you what they are and to make sure they are not coolant. they show up as sodium in tests, some show 285 ppm which looks like a massive coolant leak, but could jsut be a additive. mobil is the main company doing this to their oils.
