Sponsored by: Auxito
Another Tire And Wheel Question
Old Feb 1, 2006 | 04:49 PM
crw2's Avatar
crw2
Question Another Tire And Wheel Question
I have recently purchased a 2000 f-150 ext cab / Lariat. 4.6.... (I had a 1997 f-150 reg cab 4.6) I have noticed that the speedometer seemed to be off ( speed vs. rpm ) so I figured that I would start with the tires. The sticker inside of the door says that the truck is supposed to have 275/60R17sl tires on 17 x 7.5 inch rims....right now it has 265/70R16 tires on 16 x 7 inch rims. I need to get new tires soon, should I be trying to find some 17 inch rims at the same time,or is there not enough difference in the sizes to matter..any and all input welcome....thank you.
Old Feb 1, 2006 | 07:38 PM
tinman67's Avatar
tinman67
There should only be about 1/2 -3/4 " difference between the two tire sizes with the 265/70R16 being slightly larger. This will make the speedo/odometer slightly off but shouldn't make a big difference. I stepped up in tire size about 1 3/4 " and my speedo/odometer were off by exactly 1/10 mi. With the larger tire my speedo/odometer register .9 for each mile travelled so that when it says I am travelling 55 mph I am actually travelling 60.5 mph.Yours should not be nearly so drastic.
Old Feb 1, 2006 | 08:02 PM
preppypyro's Avatar
preppypyro
I wouldnt worry alot about it, I am guessing it would maybe be 3mph off or so.
Old Feb 1, 2006 | 09:51 PM
dilas's Avatar
dilas
The nice thing about 16" wheels, that there are more tire selections to make and is much cheaper than the 17" series.
