Sponsored by: Auxito
column indicator broke
Old Feb 1, 2006 | 07:14 AM
mel2000f150's Avatar
mel2000f150
Cool column indicator broke
Last night when I put the truck into Park the indicator showed R, one off in every gear. The truck shifts fine. I know I have read this before but can't find the article. Please help.
Old Feb 1, 2006 | 11:09 PM
Racerguy's Avatar
Racerguy
The most common cuse of that is the bracket that holds the shift indicator cable to the column has broken. It is a small plastic piece with 1 screw through. You'll see it if you pull the steering column covers off.
