EGR valves
Old Jan 31, 2006 | 12:48 PM
earnhardtracer38's Avatar
earnhardtracer38
EGR valves
I've got a '93 F-150 4x4 with the 5.0l engine. Within the past month, the check engine light came on and has not gone back off. I took it to a friend with a code scanner and the computer read "EGR valve not opening." Does anyone know why this would be happening and what can be done to correct it? Do i need to get a new one or is it something else?
Old Jan 31, 2006 | 01:57 PM
natewill's Avatar
natewill
do a search in one of several forums here. there is a wealth of info to help you out.
Old Jan 31, 2006 | 02:22 PM
gatesj's Avatar
gatesj
Yeah, there's the valve that sticks, the position sensor on top of it that goes bad, vacuum lines that leak, a vacuum actuator that can go bad, etc, etc, etc. You can test the first two things with a hand vacuum pump and a multimeter.
