61 steering colum question
Old Jan 31, 2006 | 09:28 AM
8crate's Avatar
8crate
I am currently in the final stages off a ground up rebuild and may be missing a part. Is there a cir-clip that holds the tapered bush keep the steering shaft centre to the column behind the steering wheel housing? I have a workshop manual and it doesn't give any info. If anyone can help me it would be appreciated.
Old Jan 31, 2006 | 10:41 AM
cobraguy's Avatar
cobraguy
I don't remember seeing one on mine. I do remember a spring on top of it. Once you remove the wheel and turn signal plate the spring and taper bushing were next. It's been a while since I had it apart but thats how I remember it. Rich.
Old Feb 1, 2006 | 06:11 AM
8crate's Avatar
8crate
That's it you have just jolted my failing memory.
Its going to be a lot easier to find the spring than a cir-clip
I thank you.
Old Feb 1, 2006 | 03:24 PM
cobraguy's Avatar
cobraguy
Your Welcome glad to help.
