Brake fliud loss
Old Jul 15, 2001 | 05:07 PM
stryder's Avatar
stryder
Brake fliud loss
Hey all. I'm having a tough time trying to figure this one out. I'm loosing brake fluid from somewhere. Its not leaking in the 4 corners, all lines appear to be in great shape (many of them replaced recently), all fittings are tight, new master cylinder. Yet the master cylinder runs dry in about a week. This is driving me insane!!!! Any ideas????
Stryder
I'd rather be walking through a hot desert carrying a Ford hubcap than driving a POS Chevy
Old Jul 15, 2001 | 05:59 PM
shortbedford's Avatar
shortbedford
Brake fliud loss
hey stryder you didnt say what kind of brakes you have ?power manuel 2 wheel disc 4 wheel disc any way you said the master is new if this truck has power brakes i have seen the master cyl leak into the booster sight unseen pull the master and look at the back of it see if it isnt wet. also if it has rear drums pull the drum and peel back the rubber cup that covers the ends of the wheel cylinders to see if there isnt fluid in there i have seen them leak and fill up the ends if the w cyl. with fluid. hope that helps man good luck
Old Jul 15, 2001 | 07:56 PM
stryder's Avatar
stryder
Brake fliud loss
[font size="1" color="#FF0000"]LAST EDITED ON 15-Jul-01 AT 08:58 PM (EST)[/font][p]I have power brakes (front disc/rear drum). I've already checked the rear w. cyls and no signs of anything there, so it must be the master cyl. That sucks..I jsut replaced it last month. Thanks..
Stryder
Old Jul 15, 2001 | 08:12 PM
whomrig's Avatar
whomrig
Brake fliud loss
You can pull the vacuum hose off the power booster unit, and you may find brake fluid there. also you can unbolt the master, and look at it.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 16, 2001 | 06:53 AM
78f250's Avatar
78f250
Brake fliud loss
Check the seal on the master cylinder cap. Mine went bad over time and brake fluid was running right out of the top. Cheap fix.
Old Jul 16, 2001 | 08:20 AM
maydaymike's Avatar
maydaymike
Brake fliud loss
