Timing off
Old Jul 16, 2001 | 09:27 PM
x_FordMan_x's Avatar
x_FordMan_x
Timing off
Old Jul 16, 2001 | 09:55 PM
x_FordMan_x
Timing off
i just put a holly 4bbl on my 351m and when i play with the peddle the carb blows out a big flame. only when i play with it like keep tapping it cuz it has a hessitation. i put a timing light on it and the timing is right so what do u think it could be. i also gotta adjust the 2ndary throttle could that be anthing with the flame??
Old Jul 17, 2001 | 09:48 AM
BB's Avatar
BB
Timing off
If the timing is correct, then you could be a little lean, the accelerator pump is not up to snuff or there’s a vacuum leak. These all will cause hesitation and a lean backfire back through the carb.
