Piston-to-Bore Clearance
Old Jan 30, 2006 | 10:19 AM
frankalonge's Avatar
frankalonge
When a piston manufacturer specs the piston-to-bore clearance is that clearance for each side or the sum of both sides?
As a specific example, a set of Badger pistons for a std bore are 3.997" in diameter. Badger specifies a .0025 minimum clearance. Is the bore diameter that they are after 3.9995" or 4.002"?
Old Jan 31, 2006 | 09:54 PM
grclark351's Avatar
grclark351
they make it simple for you so you only have to check one side. 3.995" would be the minimum bore diameter in your example.
Old Feb 2, 2006 | 12:43 PM
packlet's Avatar
packlet
i believe grclark351 meant 3.9995. (3.997 + .0025)
a 3.997" diameter piston won't fit into a 3.995" bore,
at least not without breaking something...
Old Feb 2, 2006 | 03:59 PM
grclark351's Avatar
grclark351
oops! i get so confused.
Old Feb 2, 2006 | 05:13 PM
frankalonge
I figured that was what he meant, but thanks for clarifying just in case!
