Front end check
Old Jul 18, 2001 | 08:42 PM
sweetpea's Avatar
sweetpea
Front end check
Just got to thinking that the front end stuff on my 70 F250 might need some looking at. Any suggestions on the things I can do to check it out?
Thanks!
Old Jul 19, 2001 | 12:14 AM
Franklin2's Avatar
Franklin2
Front end check
Jack the wheel off the ground at the ball joint, and shake it at 12 o'clock and 6 o'clock, and 9 o'clock and 3 o'clock positions.
Old Jul 19, 2001 | 12:39 AM
sweetpea's Avatar
sweetpea
Front end check
No ball joints...king pins.
Old Jul 19, 2001 | 06:21 AM
jowilker's Avatar
jowilker
Front end check
Do what he said, not what he ment to say. The King pins need to be checked that way.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jul 19, 2001 | 09:09 AM
buzzard's Avatar
buzzard
Front end check
There are a few things you should check. First, visually inspect the whole steering system to see if everything looks in order. Next, jack up the entire front end of the truck and grab hold and try twisting the steering linkages to determine looseness around the joints. Then do the tire thing mentioned above to determine king pin condition. Also look at the radius arm bushings, if they are original they definitely need replacement. If you are really industrious you can also replace the axle pivot bushings at the ends of your I-beams. That's just about everything until you get higher up into the other steering components. What it really boils down to is how the truck is handling and how old the parts are.
Good luck.
Old Jul 19, 2001 | 02:01 PM
JMR's Avatar
JMR
Front end check
