Sponsored by: Real Truck
V-10 Running rough?
Old Jan 29, 2006 | 08:48 PM
nasdaqsam's Avatar
nasdaqsam
V-10 Running rough?
2000 F350SD 4X4 Triton V-10 64,000 miles.
Recently had all new COPS, boots and spark plugs installed, it was doing it before they were changed out. When it's running the exhaust smells like it is getting to much gas. Like the old carberated engines used to do when the carbs went bad, the exhaust kinda burns the eyes when you walk by. It is running a little rough and is burning gas like I'm pulling a anchor. Any ideas?
Thanks in advance
Scott
Old Jan 29, 2006 | 09:04 PM
amish77's Avatar
amish77
throwing a code?
if not then try making sure the light in the dash is working. It shoud briefly flash upon startup and shutdown.
If there's no code and still the rich condition then the only thing I can think of is ignition control module. The only ignition I'm used to that's computer controlled is obd1 and it won't throw a code with a bad module. Mine went bad and I nearly went crazy tring to find the miss. Finally had a guy tell me about the module and after replacement it ran great. Not sure to what extent your computer is wired into the ignition. There would be a distinct miss if it was bad though. Hope it helps.
Old Jan 29, 2006 | 09:05 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
First, you might want to ask down in the V10 forum, you might get more bites.
Could be a leaky injector.
Someone with a scan tool should be able to see at least which bank of injectors is doing it, if any.
The O2 sensors could use changing, but I'd get it scanned first.
Old Jan 29, 2006 | 09:09 PM
99f350sd's Avatar
99f350sd
What he said^ Fuel pressure regulator??? Get it scanned to see whats up....
Dick
Old Jan 29, 2006 | 09:17 PM
nasdaqsam's Avatar
nasdaqsam
Originally Posted by amish77
throwing a code?
Thanks for the response. The Check engine light is lit, continuously. Just started that. The biggest problem I have is that I am not going back to the local dealer and the next one is a ways a way. Maybe I can find a shop with a computer that will work.
Old Jan 29, 2006 | 09:18 PM
nasdaqsam's Avatar
nasdaqsam
Thank for the reply, Does it have to be a Ford dealer scanning it?
Old Jan 29, 2006 | 09:20 PM
nasdaqsam's Avatar
nasdaqsam
Dick
Is there any other way to check the codes myself?
Old Jan 29, 2006 | 09:45 PM
DavidT.'s Avatar
DavidT.
nasdaqsam, it doesn't have to be a Ford dealer that scans it. Anybody with an OBDII scanner can do it. You can check it yourself if you have an OBDII scanner, which can be bought. There are some auto parts stores that scan it for free. Getting the definition of your check engine light will give you a big start on what your problem is.
Old Jan 29, 2006 | 09:47 PM
99f350sd's Avatar
99f350sd
Auto zone will do it
Old Jan 29, 2006 | 10:55 PM
G Lube's Avatar
G Lube
Or Advanced Auto Parts, which is what I prefer since the Auto Zone around here has HORRIBLE people working for them, including the manager. Actually the Auto Zone around here can't even do OBDI cars anymore since they lost the connector and they gave me attitude when I asked to get a car with OBDI scanned. They said they can't do it because they don't have the adapter when I told them I got an even older vehicle tested there before. I hate Auto Zone because of those people and I am very biased. Sorry for the rant.
But referring to your problem, get it scanned first and go from there. It will be the most money saving way to do it since the test is free.
Gary
Old Jan 30, 2006 | 05:45 AM
nasdaqsam's Avatar
nasdaqsam
We have both Autozone and Advanced in town here. I didn't realize they did that. Great. I'll call both before going to make sure one has the scanner.
Thanks for all the help.
Scott
Old Jan 30, 2006 | 07:05 AM
FortyFords's Avatar
FortyFords
Make sure you get all the codes ,sometimes when they read the codes they give you the last one in the que or memory not the previous codes before it.
Meaning that the latest is not always the cause with OBDII
Rich
Old Jan 30, 2006 | 07:43 AM
nasdaqsam's Avatar
nasdaqsam
Rich
Good idea, I will.
Thanks
Old Jan 30, 2006 | 07:46 PM
amish77's Avatar
amish77
yeah and a scantool can be about 30 bucks if you wanna go that rout. one more vote for advanced auto, all the autozones I've been to have either incompetent eymployees or ones with horrible attitudes. Only wish that advanced has the rent a tool.
