Reprogramming PSOM for tires ISSUE
Old Jan 29, 2006 | 05:03 PM
Roushians's Avatar
Roushians
Hey,
OK, so I'm stuck with having to do this, and seems quite simple. One major problem is that i seem to have found a major discrepancy with which some people are reporting the conversion constants.
For example, one online calculator I used and the chart in the article located on this site stated that for a 33" tire, the conversion constant should be in the 8.6 ball park.
But, using a formula provided, I calculate my conversion ratio to be (for 33") to be in the 8.29 ball park, and there are some charts that acknowledge this number as well.
So I don't know what to do or which one to use!
Old Jan 29, 2006 | 05:13 PM
phoneman91's Avatar
phoneman91
When you calculated the conversion ratio--did you measure the actual loaded radius of the 33 inch tire??
Old Jan 29, 2006 | 05:23 PM
Roushians's Avatar
Roushians
nope, not yet. first i'd like to know which ball park the number should be in
Old Jan 29, 2006 | 05:43 PM
phoneman91's Avatar
phoneman91
I would calculate what your original tires were--and see how close the PROM setting was. I suspect that it wasnt right on even from the factory.
If I remember correctly--the PROM will allow 6 changes before it is locked in.
The published circumference of the tire isnt important in these calculations--only the loaded and mounted radius of the tire is important--and it will be smaller than the published manufacturer radius.
Old Jan 29, 2006 | 05:49 PM
MustangGT221's Avatar
MustangGT221
I think you also need the revs per mile, I got mine from the manufacturers website.
Hopefully we can get a solid answer on this, I am in need of calibrating mine for 35s.
Old Jan 29, 2006 | 06:00 PM
phoneman91's Avatar
phoneman91
It wouldnt hurt to check the revs per mile as published--but the loaded radius of the tire when mounted on the truck and mounted on the width of wheel and at the air pressure that the owner is going to use the truck --could give the most accurate reading --I would think. The loaded radius is the distance from the ground to the center of the wheel when mounted on the wheel and the wheel on the truck under load. Effective circumference can then be figured from the actual measured loaded radius--and the calculations can be that much more accurate.
Old Jan 29, 2006 | 06:13 PM
DaveBowman's Avatar
DaveBowman
Don't go by the circumference of the tire. The best and most accurate way is to measure the rolling diamater. First check and if needed adjust the air pressure in the rear tires, then on flat cement/pavement mark the tire and the ground and roll the truck so the tire makes one full turn and mark the ground again. Then measure how many inches the tire rolled.
Old Jan 29, 2006 | 07:44 PM
phoneman91's Avatar
phoneman91
Dave and I are saying the same thing--the effective circumference or the loaded radius will give the best measurement of the tire and will not rely on published tire size--which usually isnt accurate.
Old Jan 29, 2006 | 09:42 PM
Roushians's Avatar
Roushians
yeah, that's no problem (using the loaded radius rather than published radius/diameter)
but, what formula do i use afterwards? obviously, with the one formula, I will come out close to the conversion constant of 8.29 i got using a diameter of 32.8. but there are still charts i see out there that contradict that number, and show that the conversion constant is actually near 8.6 for 33" tires. there's a big difference between 8.3 and 8.6 :P
my PSOM is programmed currently for 9.72, which is perfect for the tire size it has (29" tires approx, 235/75/15).
Old Jan 29, 2006 | 09:47 PM
phoneman91's Avatar
phoneman91
Give it your best guess--and then see how accurate it is. Unless this has been done by a PO/previous owner--you would still have five more changes allowed by the PSOM before it locks itself.
And 235/75 x 15 are not 29 inches high--not the ones that I have measured. They are actually shorter than that. More like 28 and 1/2 inches or less.
