Small Black Line
Old Jan 29, 2006 | 02:48 PM
tenptbuck7mmmag's Avatar
tenptbuck7mmmag
Small Black Line
After I put the water pump and new fan clutch on.
I was looking over the motor on my 92 F150 4.9
I found a small black line that was broke.
I'm not sure what this Vacuum line is.
On top of the motor.The words Ford and Fuel Injection is writen.
Off to the Left side as your standing in front of the truck, theres this tube abouut 4"long.
Two of the back tubes are plug with rubber caps,and a metal tube on the top.
On the front of this tube,from left to right theres a rubber hose that goes to the powder break booster.
Then the next one is pluged,with a rubber cap.
And then heres the broke small Vacuum line.
I traced it to a small black round plastic part that has two more tubes that go off from here.
The left tube goes into the cab.
The right tube goes to the Air Conditioning.
I know this is long but I tried not to leave anything out.
Thanks
Old Jan 29, 2006 | 07:44 PM
Fully_Loaded's Avatar
Fully_Loaded
That is a vacume line but I am not sure which one. When you open your hood look at the bottom of it there should be a vacume routing diagram on it.
