Offroad & 4x4
Will they rub?
Old Jan 29, 2006 | 09:49 AM
RotGrubestier44's Avatar
RotGrubestier44
Will they rub?
Is anyone running a 33x13.50R15 on a TTB F-150 w/ a 4" suspension lift? The tires I want are 13.5" instead of 12.5" wide, and I'm worried about them rubbing on the trailing arms. I know 12.50s don't, but will the 13.50s?
Old Jan 29, 2006 | 10:25 AM
JeremyH's Avatar
JeremyH
What is the backspacing on your rims?
Old Jan 29, 2006 | 10:27 AM
oldhalftons's Avatar
oldhalftons
dont worry about them rubbing, worry about them tearing up the TTB bearings, spindles, tie-rods and seering box lower seal.
Old Jan 29, 2006 | 10:36 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
lift doesnt matter in this situation....the wheel; width/backspacing is what matters
Old Jan 29, 2006 | 11:14 AM
RotGrubestier44
all of that is taken care of oldhalftons. I know about all of that. KO76, the wheels I am looking at using are 15x10 with 4" backspacing. Also the offset is -39mm (whatever that means). Is that going to work for me? Tire fitment is one thing I am not really up on, other than what lift fits what size tires and etc.
Old Jan 29, 2006 | 07:57 PM
mustange70's Avatar
mustange70
They'll fit, as if a 35x16x16.5 boggers with 5" backspacing can clear the leafs on my truck then you'll be alright.
Old Jan 29, 2006 | 08:35 PM
RotGrubestier44
Right on, thanks mang!
Old Jan 30, 2006 | 03:54 PM
chrono4's Avatar
chrono4
you should be fine, only an extra inch, and you got the rims to do it.
